Hello all. I have seen many threads discussing similar topics, but never found a solid answer.
We are currently deciding between the 36 inch Casa and the DIY Pompeii. Our main concern re: the Pompeii is the heat-up time - if it can't be ready for pizza in under an hour then I don't think we'll get sufficient usage.
So... If I build the 36" oven according to the plans, using the proper firebrick, what kind of heat-up times can I expect? How does the time compare to the modular/pre-built ovens (the Casa line)? What factors affect the heat-up time? Type of brick? Construction method? Insulation? Or is this just a difference intrinsic to brick-oven vs refractory?
I'd appreciate any guidance you all can offer.
Thanks,
brian
Thanks,
brian
Too much rain and no roof! Ugh! Need to finish chimney and put the last couple of trusses up.
