I was recently reading and thinking about the idea of lighting the oven chamber and I know there are a few different approaches to this. Some of the ones I have seen include:
- Placing a flexible light outside that can shine into the oven (bigred did this I believe)
- Placing lights in the entry arch shining back towards the oven (post #64 on Christo's build thread http://www.fornobravo.com/forum/8/ch...html#post12844)
- Placing a light inside the oven chamber through some sort of technique (post #43 from Windage's 81" commercial build http://www.fornobravo.com/forum/37/8...t-11354-5.html)
And beyond that I have read in different threads about Neoceram, a transparent ceramic that could be used to shield a light and still withstand the heat inside an oven.
As I consider the idea of lighting my oven from inside the oven chamber my question is this: Would putting in such a light lead to more heat loss through the light/neoceram than just a regular firebrick? And if it does, is it possible that just the regular insulation behind the light would stop that heat loss? My first thought as I read the idea of using neoceram to put a light inside the oven chamber was that it would lose a lot of heat. Am I totally wrong on that?
Somebody please help clarify this for me.
Thanks,
Nate
Thanks,
Nate
