Hi there,
I would like to use homebrew mortar for my oven, but I have some questions about the ingredients:
It is always said to use "fireclay", but if I translate this, I can?t find anything here that would fit. Can I use normal claypowder, i.e. the same clay that is used by potters or for plastering walls or even in terrariums? Or is "fireclay" a certain type of refractory?
I also am not sure about the "lime", I even found the suggestion to use "quicklime", which would be CaO.
Or do you mean Ca(OH)2 ?
If so, this one is even divided into two different types, the first one only becomes hard in contact with air ( to be exact: the CO2 in it), the other one also contains other components such as CaSiO3 or CaO * Al2O3 and becomes hard even without contact to air and when under water.
So which one of the three limes is the right one?
Thanks for your help,
Christian
Christian
