Suggestions for a paint/waterproofer for the dome?
  • Suggestions for a paint/waterproofer for the dome?
    I have rendered the dome and soon I will need to waterproof it and paint it as I don't want to stick with the render colour. What are people using for this?
    Keep in mind that I have fired the oven several times and due to the insulation blankets I used the outside of the dome doesn't get any hotter than 40-50C degs so I don't need a product that can withstand high temps.
    I would also like the product to fill any hair line cracks in the dome.
    Cheers in advance for your suggestions.
    Re: Suggestions for a paint/waterproofer for the dome?
    I used Drylock for the simi-flat roof of my saferoom. I think that it only comes in white, but you might be able to add a color additive to suit your tastes.
    Joe Watson, "A year from now, you will have wished that you had started today"
    My Web Album
      Hi Dan,
      The good thing about using render/stucco is that you can use natural pigment. I use a light yellow to keep the dome cool from our hot summer heat, dark color absorb heat and get quite hot.
        I was gonna suggest Drylock. That stuff stops running water seeping into basements!
