Transition to Larger Flue - Does it Matter?
  • Mistertoy
    • May 2011
    • 62
    I am building a 35 inch pompeii oven and have been working on installing a 6" flue.
    The transition is finished and it reduces to a little under 6" x 6". The ratio of door area to flue area is about 14%
    But... I have just seen a good condition stainless steel flue that is 9" diameter
    I am confident I can install the bigger flue over the 6" x 6" square hole but I am just concerned that it may not draw well with it going down to 6"x6" and then expanding to 9"dia.
    Can anyone give me some advise if it will be a problem...
    Brett
