Wood Fired Beehive in Utah
  • texman
    • Nov 2009
    • 724
    #121
    Re: Wood Fired Beehive in Utah
    Originally posted by Pompeii Nate
    Hey Russell,
    How in the world did you get those nearly perfect angles on the cinder blocks for your wood storage area? I have been using an angle grinder with a diamond blade on it and it is not looking nearly as good as yours. Admittedly this is pretty much my first time ever using an angle grinder so my skills are not great but I hoped that they would look better than what I have done so far.
    Thanks,
    Nate
    Sorry to jump on Nate and Russell, but try a diamond blade in a circular saw if you have one. REALLY loud and nasty, but makes smooth cuts without water.
    tracy
    Texman Kitchen
    • Pompeii Nate
      • May 2011
      • 219
      #122
      Russell and Tracy,
      Thanks for the information. I hope either option is better than the angle grinder. It is tough.
      Nate
      http://www.fornobravo.com/forum/f8/p...two-21068.html
        • 5260
        #123
        Been a slow go, finally finished course 4, worked on adjusting course so dome is level front to back and side to side. Was starting to dip a little so thought now was the time to correct. Getting the hang of tying into the arch. I found that if I keep the arch one course ahead of the chain the tie-in is easier. Still a lot of shaving or grinding (flyfisherx - yes I broke out the grinder from the garage). Using a combination of the two. Heat is setting the mortar fast, mixing small batches so only doing 3-4 bricks at a time, even with soaking the bricks no wally gagging. Moving on and upward to course 5.
        • Pompeii Nate
          • May 2011
          • 219
          #124
          Russell,
          It is looking great! So how many bricks did you buy if you don't mind me asking and do you think it will be enough? I bought 250 and I hope it is enough but who knows with all the cutting to make all the tight fits. Anyway, just curious.
          Nate
          • Pompeii Nate
            • May 2011
            • 219
            #125
            Follow up on the question about cutting your base cinder block. This morning I tried to get the wet saw I am borrowing from a friend but it is lent out so I went with Tracy's suggestion and bought a diamond blade for my circular saw and it was so EASY. Thanks again to both for the ideas.
            Nate
            • dvm
              • Mar 2012
              • 242
              #126
              Your build is looking great!
              dvm
              dvm
              sigpic
              • flyfisherx
                • Jan 2012
                • 89
                #127
                That transition is looking flawless. Awesome job!!!
                Album https://plus.google.com/photos/10154...CKP9op6ilID7eA
                • flyfisherx
                  • Jan 2012
                  • 89
                  #128
                  I hear you, but the time you are taking is showing in a very good looking build. I just got past my arch yesterday and am done with my 7th course. I used the grinder a lot with it. I can't see how one can do it with the wet saw alone. Moving to the 8th tonight.
                  Just keep taking your time. Just like Gianni said. "you only get to build it once."
                  I am taking the 50/50 road. Take my time....get impatient and just say...it's good enough!
                  Dave
                  • cloita
                    • Jul 2011
                    • 96
                    #129
                    i love the large bricks Russell
                    - Jonathan
                    "If you don't know where you're going, you might not get there." --Yogi Berra
                    • Derkp
                      • Apr 2010
                      • 188
                      #130
                      Our bricks are holding up great. We used larger ones, 4.5X7-8"X16" for the floor and back of our barrel.
                      • dvm
                        • Mar 2012
                        • 242
                        #131
                        How are you making corrections between courses? Ar you grinding down high spots to the lowest point? or are you adding mortar to increase height?
                        dvm
                        dvm
                        sigpic
                          • 5260
                          #132
                          Finished Course 5 and tapered arch except for the key (waiting for mortar to set) this morning before heading out for a holiday BBQ. Happy 4th of July to all of you WFOs.
                          • Tscarborough
                            • Oct 2009
                            • 3341
                            #133
                            Looks great!
                            • Tscarborough
                              • Oct 2009
                              • 3341
                              #134
                              You have been working hard on it and paying attention to detail, you will have a wonderful instrument to cook in.
                              • flyfisherx
                                • Jan 2012
                                • 89
                                #135
                                Flawless!!! Nice work. Your gonna find it very easy going once you get over that arch. I did my 8th course yesterday in 2 hours. I did spend less time worrying about my bond joints and that was kind of a nice relief.
                                Keep up the great work!
