Mortar vent arch?
  • Mortar vent arch?
    Question I have is whether or not to adhere the vent arch to the floor. I know it is recommended to not adhere the dome but wanted to verify that the vent arch is the same.
    BTW I am building my dome and arch on top of the floor.
    Picasa photo library:
    https://picasaweb.google.com/1043493...lleryMay192012
    Re: Mortar vent arch?
    dsm:
    I looked at my old photos and I've attached it here
    You can see I only mortared the bottom brick at the very front left corner and I started to mortar the triangular brick pieces at the very front edge. I eventually mortared almost the entire front landing about 2/3rds of the way into the landing so the front floor didn't move.
    RE your question: no other mortar was necessary for the floor bricks, or soldier or 1st course (other than between them and above them). I've been told on this forum, that for those who did put a little mortar on the floor, that the heat of the oven just breaks that bond anyway as the oven expands. As you can see by that almost full brick on top of the mortared corner brick, by the time I start mortaring in the rows of the arch walls, and the oven ring rows, that's a lot of brick and mortar that's going to hold it down and it ain't moving.
    FWIW: see the soldier bricks around the left side? Before I "closed up" the dome, I added a 1/4" of the homebrew as 'cladding' around the whole dome and let that cladding cover a 1/2" down the 2" side of the white insulation board to kind of "bond" the oven dome to the insulation, but DO NOT let the mortar touch the concrete base stand otherwise it will wick away heat from the oven.
    Let's see what others have done. Maybe they'll chime in too.
    My Oven Costs Spreadsheet
    My Oven Thread
      ok thanks alot dino , my concern was how is that arch going to have any support if it is not mortared down to floor. that is the first three bricks (on left and right side) that u have in the pic that do not have any mortar to them.
        Dave,
        I just posted a new thread on the forum under "getting started" that says something like "Attaching jpegs" or something like that for instructions on attaching pictures from picasa web (the only way I know how to do it) so see if it works out for you to post your pics when you have any question..
        good luck, dino
        My Oven Thread
          Yes you need to mortar the ach brick to the floor.
            Dino has probably covered it sufficiently but for what it's worth - I mortared all the bottom row including arches and vent. I was mortaring to vermiculite board so I figured it would easily detach if there was any pressure (rather than crack the dome elsewhere. Anyway I never saw any sign that it moved at all.
            I think either way is OK!
            For uploading pics probably Dino's method is the one you need since you already have pics on picasaweb.
            If you are uploading from PC or laptop use the "Go Advanced" reply option. Then "Manage Attachments" at the "Attach Files" option. That will pop-up a window which allows you to browse your computers file system. Select your file and it will upload it as an "Attached Thumbnail". There are file size limitations but that was never a problem since I used a phone rather than a camera.
            Amac
            Link to my WFO build
              If Tscarborough say it, it true, I would do it (regardless of what I thought I remembered )
              mortar it.
              My Oven Thread
                Thanks for all the help guys, hey this homebrew mix it takes a while to cure? I was just worried cause im concerned if these brick are sticking i had soak the brick prior to laying them but when i started forming up to start my arch level i went up three blocks and did mortar it to the floor and accidently ever so softly bump it with my elbow and the three i had mortared down shifted because of the bump and they were laid about 4 hours after it happened, but the good side the bricks above stuck togther here. Am i just being paraniod and not letting it cure enough?
                Thanks,
                Dave...
                    You do not want to soak the brick, doing so kills the bond between the mortar and brick. If anything, a quick dip and shake is enough.
                      Maybe you are mixing the mortar too wet? Wet brick + wet mortar is not good.
                      In my experience, the home brew mortar should hold pretty firm once the brick is set. Hold it for a few seconds and shouldn't move after that. I'm at a 70 degree angle in my dome, and still able to set the bricks with no form and have them stick. I am hopeful that I won't need any support except for the last chain.
                      My build progress
                      My WFO Journal on Facebook
                        That I would say is normal - 4 hours after mortaring it would still be very easy to disturb a mortared brick. I don't have an exact time for how long it takes = there are so many variables that there probably is no definite time - but personally I would not put more than a tiny sideways pressure on any bricks for a long time - certainly a day or days - preferably weeks.
                        Test mortar a few off cuts together - and try to break the joints at different time intervals. It should give you an idea for your conditions.
                        Amac
                          ok great thanks for the input guys i am going to give another couple days then take it from there,,once again thank you all..
                            Thanks tscarborough...
