Hi folks,
I am on my 2nd course of a 42" pompeii build, I have been cutting my half bricks front to back, as many have to reduce mortar and help get a tight fit. I just mortared my first 3 bricks on the 2nd course, my first course was a 1/2 soldier course. My 2nd course angle is a little high, but matches the 21" mason string method. The issue I am having is on either side of the three bricks, the next brick I try and line up has a large gap where the bricks sit next to each other as they are placed flat on soldier course, pics show my problem.
Not sure what is going on, did I not cut these the right way? MY 42" is right on all the way around in regards to soldier course. Everything is real level.
I used the method of getting proper angle with string, then measureing where the string crosses front of brick to back of brick, that is what I cut and tapered off, I measured 1 brick, then cut the course (about 20 1/2 bricks). Will this angle change during each course.
I seen many that have the bricks tight top/bottom and side, which is what I ma trying to accomplish.
Should I tear the 3 bricks off and start from scratch?
It seems the problem is the soldier course is less wide and makes the transition of the circle better than a 4 1/2" 1/2 brick.
Any help would be appreciated.
Pat
Pat
