When should a oven door be used, is it for starting a fire or just holding temp in..sorry for the silly question but i really dont know
Oven door ?
Picasa photo library:
https://picasaweb.google.com/1043493...lleryMay192012Tags: None
Re: Oven door ?
Dave,
They are used for baking to retain the heat after the fire is out. There was a reference to a "blast door" (on one of your threads). Those are used when you start a fire. It allows enough air in to keep the fire going and sits in the entry. I haven't seen the need for one of those yet but you never know.Last edited by Les; 07-24-2012, 06:38 PM.Check out my pictures here:
Re: Oven door ?
Oh i see,,i guess i will be fabricating one cause i def want to start making some bread once i get to know this oven ...Does anyone have a pic of one that was homemade?"Made are tools, and born are hands"--William Blake, 1757-1827
Re: Oven door ?
Originally posted by dsm View PostDoes anyone have a pic of one that was homemade?
http://www.fornobravo.com/forum/8/le...html#post49394Check out my pictures here:
Re: Oven door ?
Originally posted by dsm View PostOh i see,,i guess i will be fabricating one cause i def want to start making some bread once i get to know this oven ...Does anyone have a pic of one that was homemade?
It can be viewed in my post "Chip's 42 in Minnesota" it is 4 inches thick FB board inside stainless and aluminum.
I will be building a glass door for use when baking bread and other foods so I can see in when cooking.
I believe a well fitting and insulated door is one very important Key to heat retention.
ChipChip
Re: Oven door ?
Here's my door; works great and nearly 5 years old:
http://www.fornobravo.com/forum/f9/k...door-3118.htmlKen H. - Kentucky
42" Pompeii
Re: Oven door ?
Ok great, i do have some heavy gauge sheet metal and 2" fire blanket left over maybe that will do the trick."Made are tools, and born are hands"--William Blake, 1757-1827
Re: Oven door ?
Here is the oven door my son in law and I made. Just using a metal brake to bend stainless steel and ss rivets. It is just wide enough for a leftover piece of the insulation board that was used under the oven floor. Then, I took piece of ss to my welder guy, who welded it all shut. Notice the feet, which keep it from falling back towards you, and the two handles for easy moving.
http://www.fornobravo.com/forum/atta...112_092508.jpg
Tom
Re: Oven door ?
Thats a good idea tom, nice job."Made are tools, and born are hands"--William Blake, 1757-1827
Re: Oven door ?
My thought process has been to use refractory cement and perlite. I am on door number 4 and it has been working well. If you scan through the latter pages of my build thread, http://www.fornobravo.com/forum/21/begun-8852-25.html , you can see all of the attempts.
