Re: 36" Pompeii in DC
After closing the dome on Wednesday, while my in-laws went out sight-seeing, I started working on my vent arch. This ended up being a bit more work than I expected, and I ended up having to finish it in the evening, and left s-curve for the chimney incomplete.
Thanksgiving morning, I took a few minutes to remove the forms, and clean up the mortar from the arches and the debris from around the oven. To my everlasting surprise, the arches stayed up!
Today, with the in-laws having gone home, I finished off the chimney base, such that it's ready for a flue to go on.
I must have mis-calculated somewhere, because instead of the opening being almost 10" across side-to-side at the top, it's only a bit over 5", giving me an opening slightly larger than 5"x6"
Still, since my oven opening is just over 200 square inches, a vent of just over 30 square inches comes to right around the 15% ratio that seems to be recommended. Given that I'm planning on putting a relatively tall flue on top of the thing (haven't figured out whether to go ceramic or stainless, round, square or what), I think/hope it will draw just fine.
If I'm wrong about that, someone let me know! I could still knock the top couple of bricks off and shave them down or something.
Cheers!
-Ryan
Cheers!
-Ryan
