Hi folks...dusty here,
I built my oven @ four-five years ago. I was fairly active on the forum back then but haven't been around here much since.
But I am gking to do it again. My pal is building an outdoor kitchen and asked if I would help build his oven.
My question to all you veterans, "if you had it to do over again, what would you do differently?"
Myself, I would insulate the oven floor better. My oven seems to hold heat adequately, but the storage ceiling gets very warm when the oven is up to temp. This tells me that I'm loosing heat through the oven floor.
Also, I tapered all my bricks on both sides and the top so they fit perfectly together and required a minimum of mortar. This was very labor intensive and not sure it it holds heat that much better than slapping' a bunch of mud in the joints. Did I mention this was someone else's oven?
Anyway, what would you do different? Les? Ken? Francis? Anyone?
dusty
dusty
Outside of that, I would use something (soapstone?) in the entry that will not stain when cooking. Pizza is not a problem but sliding the grill in and out with dripping meat makes a mess of things. I would cut the bricks again so no mortar is used on the inside and I would over-insulate again. Pretty happy with my first attempt.
