More planning questions for all the users out there?this time on hearth height. I know this has been mentioned in a few threads, but I am having a hard time coming back to where it was discussed. Anyway, I am working out my base, and having a hard time deciding on 3 blocks high vs. 4. My situation is a bit different because I poured my foundation before I knew I was going to build the Pompeii style oven, so I am going to need to cantilever the hearth slab which requires it to be thicker than the plans call out. So here are the numbers:
If I go with 3 blocks:
Foundation = 3? above grade
3 Rows of Block = 24?
Hearth Slab = 8? (On the thick side, but remember I need to cantilever?)
Insulation = 4?
Firebrick floor = 2?
Total = 41?
Add a 4th block = 49?
49? would make it nice to see in the oven, but I am afraid of the proportions being way wrong as the oven is in a fairly small space, and I can?t have it look like a tower. (Afraid of family heat?)
Any thoughts on workability of a 41? vs 49? hearth floor height? Thanks!
Carl
Insulation = 4?
Total = 41?
Carl
