I didn't have the skills to build the arch of my oven with that jam (don't know ithe proper term/name) that a door butts up to. My plywood cut out that I use as a door now (was the arch support while building the vent) fits pretty snuggly in that there is only about a 3/16" gap at most between the brick and the wood. I want to just use a piece of fire gasket rope as the "jam" as well as to make it more air tight. Is there anyway to adhere the gasket rope to brick? I've found a product called Rutland hi temp gasket sealer that's rated to 2000F, and while it states that it can be used for brick, it's best used for metal to metal.
Appreciate your thoughts and advice,
Nate
Nate
