Adding a reveal
  • spinal tap
    • Apr 2011
    • 24
    Adding a reveal
    I don't have a reveal for my oven and now see the benefit and advantage of one. I have thought about bending a steel bar to form against the arch then drilling holes and screwing it onto the bricks. Another idea is to cut bricks and mortar it on but not sure how secure that would be. TIA for suggestions.
    I can't figure out how to post pictures on web forums from my iPad, otherwise I'd have some pictures to share.
    Nate
  • WJW
    • Jan 2012
    • 388
    Re: Adding a reveal
    You should probablly figure out how to post pics. You know the old saying about a thousand words.
    The way I do it is to simply upload the pics to an image hosting site on the web. (I use imageshack.) It's free. You go to the web page. Register (about like you register on Forno Bravo). Then you simply upload the photos there. Then, you copy and paste the "embed code" and paste it into your post. It takes about thirty seconds to upload five pics and copy them here.
    For example:
    • spinal tap
      • Apr 2011
      • 24
      Re: Adding a reveal
      Lets give this a try.
      • Les
        • Sep 2005
        • 2945
        Re: Adding a reveal
        Nate - what did it take to load the pic. You did this with your Ipad, correct?
        • spinal tap
          • Apr 2011
          • 24
          Re: Adding a reveal
          Yes I did. I signed up for an imageshack account, but found out that I had to go through a process of "registering" the ipad. I don't have the ID for the iPad to get the app that allows me to access imageshack on the ipad. So I sent the pictures to a friend who uploaded them to imageshack and sent me the link.
          • WJW
            • Jan 2012
            • 388
            Re: Adding a reveal
            Looks good.
            Is the point of the reveal just allow something to seat a door against?
            If so, couldn't you just use a hi-temp epoxy and glue a length of ceramic fiber rope around the perimeter of the entry. It might require a "re-glue" every year or two, but it would be a heck of a lot easier and cleaner than adding a masonry reveal.
            JMO
            Bill
            • lwood
              • Jul 2009
              • 632
              Re: Adding a reveal
              I have the same issue. I don't think the masonry approach will last. Bending a 1.5" piece of angle iron is the way to go.
              • spinal tap
                • Apr 2011
                • 24
                Re: Adding a reveal
                Originally posted by WJW
                Looks good.
                JMO
                Bill
                Hi Bill,
                I had the same idea, so I started researching oven gaskets and contacted Rutland (a manufacturer of gaskets and other high temp products). After explaining the use for their rope, their rep quickly interjected that their gaskets are not food safe, and she did not know of a substitute product that is food safe.
                Are the ceramic fiber ropes food safe? Anyone know of any product that Is?
                Thanks,
                Nate
                • spinal tap
                  • Apr 2011
                  • 24
                  Re: Adding a reveal
                  Have you done this? I think that would be a great solution. I just need to find a rounded angle iron.
                  • WJW
                    • Jan 2012
                    • 388
                    Re: Adding a reveal
                    I honestly didn't consider the "food safe" angle.
                    That being said, my understanding of the issues presented by ceramic fiber generally have to do with inhalation hazards. I'd be very surprised if you couldn't encapsulate the rope with some high-temp silicone or something similar. I also have to question the degree to which those ropes would shed harmful fibers in that application.
                    Finally, I'd be surprised if there weren't "bio-soluable" ceramic fiber ropes available.
                    Bill
                    • azatty
                      • Sep 2010
                      • 239
                      Re: Adding a reveal
                      There are a couple products out there that use Type E fiberglass around braided stainless steel wire that will handle 1000 degrees F. Another product is Type E Fiberglass wrapped in silicon that will take up to 500 degrees F. Davlyn makes/sells both. Fiberglass can be "food safe" if it uses the right kind of resin (they make water tanks from it).
                      Remember that "food safe" generally means that food comes in direct contact with the surface. I was surprised to learn how much "non-food safe" materials are allowed/used in food preparation equipment.
                      I'd go with bending the angle iron and using floating pins to anchor it into the exterior arch (it's not structural; it doesn't have to be epoxied or anything). Now, bending angle isn't the easiest thing to do unless you have a bender, but you can cut it and bend it that way.
                      Another option is to build a reveal inside the dome. You'd essentially make another interior arch, and there'd probably be a fair bit of brick cutting and cursing involved, but you could do it.
                      • Les
                        • Sep 2005
                        • 2945
                        Re: Adding a reveal
                        How do you bend angle iron w/o notches? I would think you would have to weld and grind the surface to get a reasonable seal. Also, 1.5 inches seems a little aggressive. I think a 1 inch reveal is more than adequate. JMO
                        • spinal tap
                          • Apr 2011
                          • 24
                          Re: Adding a reveal
                          I wonder the same thing. A search turned up a few companies that describe angle iron bending. Another thought was to bend the two pieces seperately then welding together.
                          When I read the 1.5" I pictured in my mind that's the width of the steel that would lay flat and will be anchored to the brick and the "L" part piece would be 1/2" wide acting as the lip for the door to rest up against. Clarification would be nice.
                          Nate
                          • lwood
                            • Jul 2009
                            • 632
                            Re: Adding a reveal
                            Bending angle iron is not easy, cutting and welding is the only way I can think of. The thickness of the angle iron is not 1/2", it's about 1/4". Make your door so it clears the 1/4" lip. Some metal working shop should be able to do it, given the door dimensions.
                            • slopecarver
                              • Aug 2010
                              • 2
                              Re: Adding a reveal
                              Options 1,2,3 use 3 metal masonry anchors, 1 on each side and one on the top of the arch.
                              Option 1: .5" to.75" angle iron should be sufficient to seal against and won't significantly reduce the opening.
                              Option 2: Might I suggest using .75" solid square stock, making a template and taking it to a metal fabricator to bend barstock to match for a case of beer? drill and counterbore for 3 screws to pass through and into a metal masonry anchor
                              Option 3: Lightweight option 2, .25"x.75" bar stock bent the hard way, weld 3 tabs on the back of the part to bolt through into masonry anchors.
                              Options 1 and 3, keep the flange of the reveal facing in the oven so you don't need to clear it with a door or see it while looking in. Options 1,2,3, seal from the oven side with high temp silicone caulk
                              Option 4: A collapsable door, one that has a vertical axis hinge in the middle, you will have a hard time getting it to seal great but you won't have to touch the oven. To clarify If you are looking from the top down the door would look like a "V" with the tip of the v facing in, once the edges are in place spread the legs of the v.
                              Side Note, I use imgur to upload pictures, no account needed.
