Re: Vent transition: castable inner arch?
So far, the chains are fitting fairly well into the casted arch. Obviously the first two "soldier" rows fit perfectly. The third row, which is the first angled one, required cutting a brick longer than the usual 4.5" at a taper that fit the angle of cast arch. However I still think the fit is easier than the standard brick arch would have been.
On a secondary note, the back side joints certainly require a huge amount of mortar to fill. The brick shims cut some of that and perhaps add a bit more stability, but still the >1" gaps are a bit nerve wracking.
