Hello All,
I live in Maine where frost is a mojor concern of mine. I'm going to pour a slab 4' below the ground and build up my concrete block stand from there. My question is this:
Once I get to ground level, do I wrap my cinder blocks in some sort of waterproof wrap to keep moisture out? Do I fill the interior with the excavation I took out of the hole? Also should my foundation slab be the exact dimensions as my block stand?
Thanks all.
Thanks all.
