Re: Pompeii Oven Misprint?
Hello Sam,
I can't tell from your Sketch-up whether you are planning just one openning under your hearth for wood storage or if you have another openning on the backside. It is the general concensus here on this Forum that multiple access points for your wood are better. You may already know this, but I thought I would pass that along before you get too far. I wish I had researched more on this website before I finished my block stand because the reality of crawling on hands and knees to pull wood from the back of a 5' deep block chamber is not very appealing.
Regards,
AT
That makes sense, thanks for the clarification! I went through the plans and designs and have a pretty good idea of what I am going to be putting together. I sourced a lot of the materials already and will definitely have to use your suggestion and take a tape measure and figure out the exact dimensions.
I strated another post in "getting started" after we broke ground on our build last weekend. I will have to consolidate and post one continuous thread in construction. Deejayoh, I actually found the pictures of your build and it is extremely similar to what my brother-in-law and I had sketched out and discussed. I figure I will post the build thread together in this section of the forum. We have a lot of digging left to do, though we aren't putting up an entire retaining wall like your build! Though the amount of rock in the soil should lead to a pretty interesting excavation. Once I have the sketchup model properly drawn to size with the right dimensions I figure I can ask about good sources in Seattle. I know that there is a local company "Rolling Fire" that sources FB kits and material, any experience with them? I was thinking for firebrick and mortart and ceramic boards perhaps?
Regardless thanks for the welcome and help, be back after I move some earth.
Sam
Hey Sam-
Welcome to the forum! Your build sounds very similar to the one I did last year. I built an oven and BBQ terraced into a hillside. I am in Seattle too. Happy to share any insights on sourcing and challenges with the approach.
Dennis
Hi Sam,
It's not a misprint; more like a variation in consistency due to the evolution of the plans (does that make sense??)
Use the plans as a basic knowledge set to begin designing your oven. What is most important about the foundation is that it will hold your block stand.
Different parts of the country (and world) have different sizes and shapes of building materials. Concrete blocks come in all sorts of sizes and vary from Home Depot to Lowe's, etc. Material variation combined with oven design means that everyone's block stand & foundation will be different.
Before you can design your foundation or block stand you need to know the exterior dimensions of your finished oven: exterior diameter of dome + insulation + type of finish (stucco dome, house, etc).
Then figure out your hearth size to fit the oven, then block stand size, then foundation. Funny that the foundation is the last thing you need to calculate
In the planning stages, I took a trip to Home Depot with my tape measure and measured the dimensions of their concrete blocks. Then I was able to design my block stand, assuring it was the right size for the oven.
Hello All,
I just broke ground on what I'm hoping will be a 42" Pompeii oven/bbq combo. I have a large amount of loose rock/soil to dig out before I get around to actual construction, but I figure starting now will make it so that when spring really arrives in the Pacific Northwest I'll have all my materials sourced, plans drawn and research completed. The idea is to build the oven with attatched bbq into the side of a rocky hill next to my house.
One initial question I had was in the plans for the Pompeii oven there is a table in the beginning that states the foundation for a 42" Pompeii oven would be 73" x 86". However in the material list it describes materials for an 80" by 94" foundation. Before I go drawing up any plans I was wondering if perhaps I missed something in my read through that explains the difference? Thanks for any clarity as I continue my attempt at reading every single build and piece of advice on the forum before April.
SamTags: None
