What do you have for Insulation
  • #31
    Re: What do you have for Insulation
    Originally posted by mrchipster View Post
    Perlcrete will hold up but is not the best insulator directly against the Firebrick so I would recommend 1" - 2" of ceramic board next to the Firebrick
    Foamglas is very brittle and hard to lay firebrick directly on so a layer of 1-2 inches of creamic board would be recommended next to the Floor brick.
    That is how the oven I am assisting with right now is being built.
    Floor Brick
    1" Ceramic Board
    4" Foamglas
    Stacked as above
    My oven is
    Floor Brick
    2" ceramic FB Board
    2.5" 7/1 Vermicrete
    I wish I had more insulation under the floor.....
    Chip
    I think I'm going to stay away from the Foamglas. What would you change on yours? Would you have had 4" of FB board and 2.5 of the 7/1 Vermicrete or would you have kept the 2" of FB and increased the Vermicrete layer. Also what's better perlcrete or vermicrete? Thanks
    Link to my oven build on YouTube:
    http://www.youtube.com/watch?v=Ujb7lqVcSzQ
    • #32
      I have my vermicrete contained in a concrete cutout so it is fully supported on the sides. This is not a recommended approach if you are building an igloo style as you can create a bathtub type effect and trap water, but I have a nice house over mine,
      I would have gone with 4 inches of vermicrete or perlcrete at a 11/1 ratio to increase the insulating value and then 2 inches of ceramic on top of that. Because the way I built my hearth slab fully contains the vermicrete I could have had the very high ratio perlite or vermicrete without any structural issues if not contained that ratio is quite weak at the edges.
      The reason we are using foamglas on this next project is that I got some real cheap and it is also a great product.
      I guess I would use the Foamglas if I had not given it to the person who I am helping,
      From what I have read Perlcrete is slightly better insulation value
      Chip
      Chip
      • #33
        Chip
        Is it because of cost that most people don't just put 4" of ceramic board down under their oven floor? Seems like the easiest option, but not the cheapest.
        • #34
          Agree, Cost is high on the ceramic board. and not a huge return after you get outside of 2 inches unless you cannot afford the extra thickness,
          I see heat bleeding into my structure with the current insulation that is why i wish I had more and a higher ratio in the vermicrete. or foamglas would have been good also.
          Chip
          Chip
          • #35
            Chip
            I would have thought doubling the ceramic board insulation might have a large return on heat preservation? Why not with this board? Would a 7/1 vermicrete mix be stable enough to not be enclosed by regular concrete? The FB plans show the vermicrete extending to the edge of the slab with a firebrick island in the center. I'ld be worried about screwing metal studs into the vermicrete. I also don't like the idea of building an island of vermicrete with concrete around it. Worried about water like you although with a full enclosure I don't see how any water could get in there.
            • #36
              7/1 is plenty stable not enclosed.
              4 inches of ceramic would be great except for the extra money. but i think that would be an ideal setup if you can afford it,
              I agree on not extending vermicrete layer to the outer edges I would much rather mount direct to real concrete and that way you could embed anchors in the concrete while wet, and just bolt the studs down. or drill in anchors and put in screws.
              You should still have the vermicrete and board extend beyond your brick an inch or so so as to not wick heat away from the oven, I would elect for 2 inches as sometimes the placement of your oven will vary slightly over original intended location that way you have a safe zone,
              Chip
              Chip
              • #37
                Just my opinion, but I think 2 inches of the CF board + x inches of a less expensive material is a good way to go. The CF board will do most of the work, so under that you don't need as expensive a material because the temps won't be as extreme through 2" of CF as they are under the floor. Lots of builders pour vermicrete and then put CF board on top of that and have good performance.
                One thing to consider is how high your cooking surface will be with your final insulation. I am not sure if you have poured your base yet, so you may more freedom with that. I know that in my case my base was there at 40", so I could only put 3" of insulation under the oven (2" of CF + 1" of a 1900 degree board that was only $10 a sheet). For a relatively mild climate like seattle, that is plenty - but in maine you may want to better isolate your oven from the slab - Chip has the experience there.
                My build progress
                My WFO Journal on Facebook
                • #38
                  I found a place that is local that sells pre fabricated ovens and they place Skamol under their ovens. It's a 3" thick board. Here is a link to the board:
                  http://www.skamol.com/media/1[calcium_silicate_slabs]A4.pdf
                  You might have to copy and paste the link to your url for some reason.
                  Is this a good one to use? If so this will save me a lot of time and money on shipping !
                  • #39
                    that's Cal-sil. It should work just fine. I have that for my lower layer - but plenty of people have used it by itself.
                    There are some threads here on Cal-sil vs. Ceramic Fiber board if you do some searching. Cal-sil is certainly quite a bit cheaper!
                    here is the link fixed
                    Skamol
                    My build progress
                    • #40
                      They sell it 3" thick. I was thinking of using 3" of that and 4" of vermicrete below it.
                      • #41
                        That may be overkill, unless you need the additional height. Cool face of 3" of insulation should be <= ambient temperature when your oven is going full blast
                        My build progress
                        • #42
                          Actually I don't need the height I can make it up in my slab elevation. So 3" of that board will do it!! That saves me having to mess with vermiculite. Ahhhh some good news.
                          • #43
                            Calcium Silicate (at least 2" thick) will work fine. It is being used successfully under many ovens on this site. Are you buying from the board from the oven dealer, or a local warehouse?
                            Maine has a large pulp and papermill industry. The industrial insulation suppliers which supply them will usually have the best prices. Note: They usually will not sell less than a case. 2" calcium silcate usually comes in a box of 7 boards that are 1' X 3' X 2". If you search and call for prices, make sure that you use the term calcium silicate, and ask the sales clerk to repeat that back to you when getting a quote. Stay away from "brand names", they are meant to be confusing .
                            • #44
                              Glad to see that you have a plan . But, vermicrete ain't a problem. It has it's place, if it's done right .
                              • #45
                                Yes, butto not have to do that and being able to buy the cal sil board 10 minutes from my house is nice. My sister is a chemical engineer and works in pulp and paper. Ill give her a call. Thanks
