I think you probably should have some air space for circulation purposes.
When you start messing with the design, you may find as I did that the combo of acceptable clearance for the eaves + a roof pitch that doesn't look odd will dictate your flue height.
but you are a long way from needing to decide!
Here's my housing under construction for reference, showing dome clearance, pitch, and height.
