Should I cure my 42 inch Pompeii before I install insulation or after I have read of people doing it both ways?
Re: Curing oven
My plans are just like yours. I plan on curing and having it full blast before i put the insulation, because i can see how the oven performs, if it cracks, or i should say how much it cracks etc.Matthew 19:26. With God all things are possible.
Re: Curing oven
I'm either going to use a single walled pipe or no pipe, just vent it out with a red brick chimney. I am not paying $$$$ for a double walled pipe. Thats just me.Matthew 19:26. With God all things are possible.
Re: Curing oven
GuddayOriginally posted by V-wiz View PostI'm either going to use a single walled pipe or no pipe, just vent it out with a red brick chimney. I am not paying $$$$ for a double walled pipe. Thats just me.
I read an English build and his using an enameled single steel pipe. Sounds more durable than plain steel but is it available , I'm going to be keeping my eye open for that it sounds usable?
Regards daveMeasure twice
Re: Curing oven
Isnt enamel just the finish? If so you can even apply engine enamel from a spray can.Originally posted by cobblerdave View PostGudday
Regards daveMatthew 19:26. With God all things are possible.
Re: Curing oven
GuddayOriginally posted by V-wiz View PostIsnt enamel just the finish? If so you can even apply engine enamel from a spray can.
I think it's dipped and then oven baked. I don't know about engine paint would it be hard to spray the inside of a 6 in steel tube. I now have a mental picture of someone's arm up the elbow in a steel tube with a spray can. Recon one of those gloves that they use to inseminate cows. I'm not letting this thought go any further.....
Regards DaveMeasure twice
