I am currently planning my wood fired oven and want to make sure I get it right first time, I have been researching the use of paper concrete as an under hearth insulation medium, has anyone out there had any experience with this type of construction?
Paper concrete
Re: Paper concrete
I'd play safe and go with the tried and tested insulation as it is the hardest to correct if it goes pear shaped!
NeillPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
