I purchased portland to make home brew last August, and I'm just now getting to the point where I need to use it. The bag was in my garage over the winter, and it's still mostly powdery, with lots of 1-3mm granules. I made a batch with it, and the bricks stuck well. Is there any reason why I shouldn't use it after sitting for so long?
year old portland
Tags: None
Re: year old portland
I took one of those tile laying for dummies classes a few years back. The instructor implied that grout and pretty much all portland based products have a shelve life. I don't know how true that was as I have used really old grout and it seemed to work just fine. But... if you have any lumps in the cement - just toss it. The cost is squat.I purchased portland to make home brew last August, and I'm just now getting to the point where I need to use it. The bag was in my garage over the winter, and it's still mostly powdery, with lots of 1-3mm granules. I made a batch with it, and the bricks stuck well. Is there any reason why I shouldn't use it after sitting for so long?Check out my pictures here:
If at first you don't succeed... Skydiving isn't for you.Comment
Portland cement is hygroscopic. Even if it is still powder it may be no good. Trash it, especially if it has been sitting on the floor.Comment
What about the lyme? Any shelf life on that? I kept them both on a plastic sheet in my garage in NY.Comment
Unless the lime was in an air tight container trash that too. The only good lime that old is lime putty sitting under water...but we won't go down that road in here right, T?Old World Stone & Garden
John RuskinComment
