Hi, I closed my dome yesterday. I had difficulty using commercial refractory mortar, HW Mortar Mix 413, and switched to home brew. I have 2 1/2 bags left and would like to use them to add thermal mass. I could use advice about how to do this. Specifically, what if anything should I add to the mix (such as fire brick sludge, sand, etc). Any help is appreciated.
Questions on cladding
1 PhotoLink to my build here:
http://www.fornobravo.com/forum/f6/3...lly-19181.html
Selected pictures of the build.
https://picasaweb.google.com/1168565...g&noredirect=1
sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert EinsteinTags: None
Re: Questions on cladding
Adding extra thermal mass can be counterproductive in that after a few hours of firing the heat may have hardly penetrated through to that layer. If you stop firing then the cooler outer layer will be sucking heat from the inner layer. You will use more fuel to heat the whole oven properly. My own oven has only 50 mm walls and takes at least two hours to get it properly heated. I can clear the dome easily in under an hour, but the heat has not penetrated right through the walls at that point.
If you add sand or aggregate to your mortar you will weaken the mix. I presume your mortar uses calcium aluminate cement, so you would need to add some more of that to bring back the strength if you add any extra aggregates to the mix.
Are you doing the cladding layer for extra strength or for added thermal mass? If the latter then it wouldn't matter if the mix is weak.Kindled with zeal and fired with passion.
Originally posted by Bec1208 View PostHi, I closed my dome yesterday. I had difficulty using commercial refractory mortar, HW Mortar Mix 413, and switched to home brew. I have 2 1/2 bags left and would like to use them to add thermal mass. I could use advice about how to do this. Specifically, what if anything should I add to the mix (such as fire brick sludge, sand, etc). Any help is appreciated.Old World Stone & Garden
John Ruskin
Originally posted by stonecutter View PostNothing need but water for bagged mortar mixes and a couple bags probably won't put more than 3/4" over your dome...IMO, no big deal. Or try and sell it on CL.2 PhotosLink to my build here:
