I want to make an IT, but don't have a welder. I have made a very crude one out of a door hinge, wood strips (for the arm) and a door bracket. Curious if there's anything out there that's better. How'd you make yours if you didn't weld? A link to your build would be great.
Tags: None
Re: IT without welding?
jimkramer
another method is to use a length of threaded rod with a couple of nuts, adjustable and strong!
Cheers.
NeillPrevention is better than cure, - do it right the first time!
Neill’s Pompeiii #1
Neill’s kitchen underway
Steellearning- how'd you affix the threaded rod at the bottom? It seems people often use either a door hinge or caster. I suppose I could drill a big hole in a hinge, then bolt it in place.
The bolt was only used to hold the long nut in place during welding and was removed after. I didn't want to have a nut on the shoe side of the bracket (where the brick is seated). Plus I wanted to try welding...Originally posted by brickie in oz View PostSo why did it need welding?
It would stay in place by locking the thread up surely?
This is what it looks like... Hope these photos help explain.Originally posted by jimkramer View PostSteellearning- how'd you affix the threaded rod at the bottom? It seems people often use either a door hinge or caster. I suppose I could drill a big hole in a hinge, then bolt it in place.
Not the most beautiful welding, but it stuck...
2 Photos
1 Photo
Much better idea, wish I had thought of that...Originally posted by deejayoh View PostCountersink a machine bolt through the bracket into a long nut like Steellearning used. Secure the whole thing with some thread locker and/or epoxy. The bracket doesn't need to be all that strong. It just needs to be secure.
[ATTACH]37580[/ATTACH]
