My dome is out of circle, in some places up to about .5 inches. The dome goes around the floor bricks. Maybe the floor got out of wack before I started the dome - winter came in between those steps. I didn't use the IT until now, so now I can see it painfully clearly. I'm now on the 3rd course (1st course was splits that raised it up so I wouldn't get a peel caught under dome brick.) Should I correct it right away? If I do, it looks fugly where brick sticks out 1/2". Or do I correct it a little bit on every course? Or do I not worry about it until I get close to the top? I'd rather correct it higher up, where you won't see the bricks not aligned properly unless you stick your head in.
Tags: None
Re: dome is out of circle
bring it back a little bit at a time, over 2-3 courses. It will turn out just fine.
I went off a bit as well on a course that I did not use the it. It wasn't bad so I made a executive decision to just fix it on the next course. Now that it's done I can't even notice it but not to say it doesn't bother me!! I just push the fire over to that side and problem fixed.
