Re: Somewhere in the slumering suburbs of Stockholm
Wow! looks good! One thing I have noticed, you will either need a insulated door on the oven it self, or, You will need a damper [flue] on you exhaust...Thats the part I told you to look at Gulf's or Brickie's builds... they have insulative dampers..... So, when you shut the door the heat won't just go up the exhaust stack, or leak ...adjust the damper and "smoke" as well..If you want to hold heat or bake....Might add some buttress to the outside of your arch columns as well..Out side pressure, need mass to hold....How are you going to finish it?
Confused and astonished with big eyes and empty on words.
Hopefully.
