40" corner build in central TX
  • ogorir
    • Aug 2013
    • 61
    #61
    Re: 40" corner build in central TX
    Should I do both coats with marble, or just the brown coat? I'm going to need 3.5cu ft if I need to do both. Do you stock it at MPI? I have one guy I can check with here for marble, but it's a long shot.
    Time flies like an arrow; Fruit Flies like a banana.
    My oven (thus far): http://www.tinyurl.com/ogorirsoven
    • ogorir
      • Aug 2013
      • 61
      #62
      My lead in town panned out for once. My co-workers neighbor does pools, but they sub out all the gunnite to an outfit in dallas. He happens to have 2 pallets of marble dust left over. I'm getting at least 4 bags, maybe more, for 2 handles of Jim Beam. My co-worker is possibly the most skilled haggler I've ever met, I might wind up with more.
      hopefully it will warm up again towards the end of next week and I can insulate and stucco the dome.
      • GarnerAC
        • Jul 2013
        • 242
        #63
        I dont know how I missed your build thread but WELL DONE! Im with you on the COLD, maybe we can both get something done with this weekends warmup in CEN-TEX!
        My build documentary page:
        • ogorir
          • Aug 2013
          • 61
          #64
          I wish! If I'm on my A game through Sunday, I'll be able to get the dome blanketed, insulated, and stuccoed next week.
          Unfortunately, that means in the attic: finishing the radiant barrier, building a new platform around the attic stairs, sealing penetrations, re-doing the upstairs furnace chimney that's currently venting into the attic, blowing in 13" of cellulose; in the garage: replacing the blend door assy and actuators on my neighbors grand cherokee, replacing the ball joints, drivers side CV, and power steering pump on my wife's car.
          We'll see.
          I did get 5 bags of marble dust, so I'm good to go for the stucco. I just need to shell out $18 for a 70 lb(!) bag of white cement. That is made in Waco(!). Kind of like how I can't find hydrated lime in Waco, yet there's a lime plant 5 miles north of town. I swear that finding materials has been the hardest thing about the project by a wide margin.
          I've been lazy about posting pics, I'll get on that when I'm not trying to run in 5 directions at the same time.
          • Tscarborough
            • Oct 2009
            • 3341
            #65
            The lime plant in Clifton is bulk only, so if you need a truckload they can help you out. Their bag plant is in New Braunfels. $18.00 a bag is steep for white around here.
            • ogorir
              • Aug 2013
              • 61
              #66
              I was referring to the plant in lacy-lakeview. It's possible it doesn't exist anymore, though, because I got that info from my co-worker who grew up there. It still just surprises me that it's that difficult to find.
              I'm going to check around on the cement, but it's $18 at the box stores, which is crazy. I know darden stocks it, but I haven't priced it there yet.
              • ogorir
                • Aug 2013
                • 61
                #67
                I just stopped at darden while I was out at the welding supply, 11.25/ bag for the same Lehigh white cement. 16.80 for white Portland. I bought 2 bags of cement, one Portland, and I got a freebie bag of white cement that fell off the pallet and broke open. I'm looking forward to next week
                • ogorir
                  • Aug 2013
                  • 61
                  #68
                  It's been a while... I just recently got back on finishing the oven. Since winter has broken, I've been busy using the oven
                  I got the hearth extension poured and decorative arch done this weekend. trying to get the first couple courses of chimney casing done so I can start the stucco/perlcrete.
                  I had a hell of a time trying to stick perlcrete to the blanket, so I'm going to build up a few inches of stucco, then backfill with perlcrete, at least until I get halfway up the dome. It should be easier up there.
                  • GarnerAC
                    • Jul 2013
                    • 242
                    #69
                    Superb looking front arch. Gotta love Stone and Brick together.
                    • ogorir
                      • Aug 2013
                      • 61
                      #70
                      Thanks! It was a last minute addition. I purchased 12 common 3-core red brick from lowes while I was laying the oven out initially and they fit the opening space better than the king-size brick I built the rest with, so I decided to use them for the deco arch. I couldn't figure out how to make a decent looking keystone with the brick, though. I needed a few more bricks, so I went to lowes and bought a few more (at $0.73/ brick :/ ) and checked over in the outdoor gardening area and sure enough there was ONE nice yellow piece of Austin stone. That stuff cuts and chips beautifully, I see why everyone uses it around here.
                      • ogorir
                        • Aug 2013
                        • 61
                        #71
                        I was just thinking... should I use homebrew for the first few courses of chimney brick? It is sitting directly on the flue arch, so it's going to get fairly hot.
                        I've only got a few chimney bricks set, not the end of the world if they need to come back out.
                        • EricU
                          • May 2010
                          • 152
                          #72
                          I used the homebrew for my entire chimney stack, why not?
                          Your build is looking good, have you started cooking in it yet?
                          Thanks, Eric
                          My 42" dome build pics in Napa
                          My build thread part I
                          My build thread part II
                          • ogorir
                            • Aug 2013
                            • 61
                            #73
                            I've been using type-s quikcrete profinish premix mortar for the decorative stuff and I like the way it works.
                            Based on 25psf wind load(roughly 100 mph), it doesn't really matter what I use, the load is almost negligible (125 lbs).
                            • ogorir
                              • Aug 2013
                              • 61
                              #74
                              Chimney case is done, more or less. It's a bit rustic, but a learned a lot about keeping everything true by the 6th course (doh).
                              I'm going to try to fill in a row of bricks behind the corbel if the rain will let up tomorrow and do the mortar cap. In hind sight, I think I went a course too tall, as my flue is only about 3 inches proud of the top course of brick.
                              I'm going to fab a stainless flashing/cap/spark arrestor/air director to sit on top, just need to locate some stainless. I was originally going to do copper, but I can't really justify the expense.
                              I guess I need to stop procrastinating about covering the dome, that's about all that's left
                              (yes, I know, terrible picture quality. iPhone doesn't do so hot in the dark)
                              • Novaslo
                                • Dec 2013
                                • 279
                                #75
                                Wow that looks great....Crazy to think how much weight it is holding. Nice Job...
