Re: Is this plan (oven entry) structuraly strong enough ?
Vcrete is pretty good under compression, and the more portland in the ratio, the higher the compression rating. The problem, as with regular concrete and most masonry, it has weak tensile strength. That is way reinforcement is added to concrete or cladding....it's just that vcrete/perlcrete is weaker in bind strength as well, compared to concrete or mortar.
I just did not know where it came from anymore.
