Hi Guys, my dome is in, covered with fibreblanket and about 75~100mm of vermicrete. My next step is to cast a concrete countertop in situ, after which I'll render the dome. The intention is that the countertop slopes gently away from the dome and the plastered finish on the dome sits on the countertop so water is naturally carried away. My intention is to complete the countertop as follows(inspired by Amacs concrete countertop).
1. Cast the countertop in situ using marine ply or something like that with an overhang, about 50mm probably.
2. Theres a product I havent seen and I believe it some kind of fibre, like hair, that can be used to reinforce the counter. Is this a better product than steel to use as the counter might be a bit thin for steel? Whats this product called?
3. Make a white mix of mortar, white cement, and can I buy white gravel or should I just use a white sand/cement mix? have never seen white gravel.
4. Should my mix be fairly dry as I see a lot of instructional vides that seem to use a 'very' dry nearly putty like mix? I would have preferred a wetter mix to ease getting air bubbles out?
5. Pour the mix into the shutter until nearly full then wait for it to start to go off, a few hours maybe. Make another mix with broken glass in it and fill to top of shutter. Is this the correct technique or should I have glass right through the mix? would too much glass weaken it structurally?
6. When cured, grind surface back with progressively finer pads on a 9" angle grinder. Do I really need a variable speed grinder?
I'd like to get a good shiny finish but I dont expect it to end up like granite kitchen countertops.
Any comments on my technique appreciated?
Richard
Richard
) to cast in situ as the alternative would be to cast in sections and then get them to try and fit around the dome.
