I'm starting this thread in hopes of hearing stories such as mine about locating the key elements to oven construction.
As you may have read on another post, I am at the stage of beginning my hearth and dome: Slab, block stand, and supporting slab/insulating slab are done.
My first problem was locating HeatStop 50 mortar (recommended by James as a very good substitute for the Refrax which FB is currently out of. I visited and called 8 different 'authorized' dealers as well as one refractory supplier. Only 2 carried it. The first rock/stone yard only had 15# pails would not order the 50# bags I needed, this place also had what turned out to be a very high price on light duty firebrick (fireplace brick as they called) - $1.38 each. Another dealer offered the HeatStop 50 at $95 per bag (I will use plane mud before I let anyone rob me for so much.
Finally, the 8th call landed me a cement products company 50 miles away in Lakeland FL. The have HeatStop 50 at $55 per bag...SOLD, I will be there soon as possibly...These guys were great, turns out they have the exact same firebrick (light duty fron Carolina Ceramics) that the first (very large) Tampa supplier would sell me for $1.38 each at a LOW .77 per brick...SOLD again, I purchased 210.
The refractory supplier was an experience in itself. They 'trotted' out the fireplace/oven expert who insisted I needed the Alsey unbranded MEDIUM firebricks at $2.25 each. OUCH!! Also recommended to products that have been 'ripped' by other members for ther poor results, thos being Super Hi Mul refractory mortar (airset, premixed in a tup) for setting my bricks and another product Greenpatch 421 for coating the dome, another water soluable airset mortar. Even did his best to convince me that the only way to REALLY do it right would be to cast the entire dome out of castable refracory. With nothing to sell me that was on my list, I was outa there...with them sarcastically wishing me good luck with those products you 've chosen
Bottom line...spend alot of time calling and visiting these suppliers, Here in central Florida, they are only vaguely familiar with fireplace building with no clue about ovens. Everyone I called could only tell me they had 'standard' fireplace brick, and didn't know any of the specs. I had to call the manufacturers to get the Temp rating and alumina content.
The only drawback to my 77 cent brick is that they are wire cut - making the edges,length, and width a little off on some of them.
Also, the size is slightly smaller 2 1/4 x 4 1/4 x 9
Let me know how easy or hard it has been finding the right products, i'd like to hear about it.
Randy
Randy
Still have not figured a way to keep the driving rain out of the entry.....just using a typical door probably won't do it
