1) My ovendesign started out as a Breadbuilders oven, transformed later into a Pompeii oven. I skipped most of the mass in the design but still have more mass than most of the Pompeii ovens shown on this forum. I have a 6" floor (3.5" concrete layer + 2.5" firebricks ) and I just finished the dome which is now 4.5" (firebricks). I'm planning to add another 1.5" of cement/sand/fireclay mixture (the same I used for brickmortar) to make sure that the dome and floor are of equal thickness. Because 1.5" inch is quite a thick layer I am considdering applying a thin wire mess in the middle of the layer.
Any comments on the thickness of the dome or the use of a wire mess? Is it easier to add the wire mess first and than add the mortar? Or should I first put half of the mortar, after that the mess and after that the other half of the mortar?
2) The oven I build will be Iglo shaped. In the Pompeii plans there is a description on how to do this. The advise is to use 2 thermal blankets for isolation of the dome. Is this really nessecary? I was thinking on using only perlite (4").
Thanks upfront for your help.
