Hello all
I am planning to build an oven for my wifes father. We live in on the south end of Lima Peru. Due to the lack in quality of bricks here, I am thinking of using rock instead. The brick here is very brittle. I am guessing that rock would work the same as brick would, but with the higher density of rock, it would take a little longer to reach temperature, yet would hold the temperature longer. Would this be correct? Has anyone here built one out of rock? I also have to find a material here that will work for the floor and work as insulation. I was thinking about a rock floor with a thin layer of sand and I can place flat tile as a base and it can easily be replaced when it breaks as I wouldn't expect the tile to last long. Things here in Peru are not made with the same quality as they are made in the states and other countries. Any advice would be awesome!
Josh
Josh
