Vent location
  • Campmaki
    • Dec 2013
    • 141
    Vent location
    Gentleman and Ladies, Noticing a lot of different designs. One thing that I am looking at is vent construction. Some vents are built separate from the dome , while a few have been built together. In the latter, the domes arch top is used as the back support for the chimney, clay or metal. Is this good practice?
  • wotavidone
    • May 2011
    • 800
    Re: Vent location
    Either will work, and I reckon it would be a little stronger if everything - dome, inner and outer arch - was integrated.
    However, it would possibly be better from a heat retention point of view if the outer arch that carries the flue/chimney is is thermally isolated from the dome itself.
    But maybe not.
    What stopped me building an entry that combined the inner arch, the smoke chamber, and outer arch/entry in one monolitic construction was that I wanted a reveal to put the inner door against, and that meant a fair bit of brick cutting of a sort that I didn't really have the equipment to do.
    And, with the inner door fitted, you really do end up with a fair bit of uninsulated brick "wicking" heat out of the oven. If you had a damper in the flue, and an insulated outer door as well, that would be minmised ptretty well.
    • stonecutter
      • Jun 2007
      • 2003
      Re: Vent location
      What is the concern?
      Old World Stone & Garden
      John Ruskin
      • Greenman
        • Feb 2013
        • 1123
        Re: Vent location
        There are plenty of variations on the theme and the common denominator is that they all work. Mine has a thermal break of kinds and I am happy with it and the time it holds heat for but it depends if you are looking for a small suburban sedan or want the Veyron experience.
        How they are constructed and how they look probably reflects the expectations of the builder.
        Cheers ......... Steve
        • boerwarrior
          • Apr 2013
          • 454
          Re: Vent location
          I went with the "together" (integrated) approach. It seemed to my engineering brain like this would be stronger and I do use the dome to support the back of my chimney.
          But I agree with Steve - I think either approach is fine
