i relaize that this is a shot in the dark, but perhaps james or another mortar expert has an opinion about adding thermal mass to my tandoor. here's my thinking:
the thermal mass of the clay pot seems a bit too small, so i thought i would wrap the pot with wire mesh and then mix up equal parts fireclay and sand and then add 1/6th part cement (a 6-6-1) ratio and then slather about an inch of that over the pot.
i want the mass of the additional clay but am unconcerned about structural strength except to the extent this weak mortar would adhere to the pot to the extent needed to keep any cracked pieces of pot from falling into the chamber. with so much clay in the mortar the thermal expansion and contraction should be similar to the terra cotta pot (i hope).
i figure as long as the pot doesn't fall inwards i can always repair any cracks. (however, the perlite will be poured loose and i will hing the top counter just in case i ever need to replace the pot with a new one).
