Re: Concrete Foundation Base Cracked...Damn it!
My thoughts are simple, put frost walls and footings in, at the beginning. There is not a solution for the cracked slab. Hope for the best, but you can not control the freeze, thaw cycles. How do you put foam under a cracked slab after it is poured? Are you rigging the whole oven and picking it up with a crane? As far as tying the slab to the walls with pins,I would tend to leave it alone as this could make the oven move with the slab.
