Re: 36" in Chapin, SC
Not sure what you mean by gauging. I measure by volume and then mix with a paint mixer, slowly adding water until it has a workable consistency. I had mixed up one batch that was a bit soupy and used it in the area where the cracks are. The sand is really sharp and pretty fine. The mortar does not seem to be drying very fast at all. The left over mortar dries to a white color and even the first joints have not turned white and still look wet.
Is this going to be a problem and if so, how do I fix it?
View Post
