42" Pompeii oven in Gloucester, Virginia.
  • Yannick
    • Mar 2014
    • 72
    #31
    Re: 42" Pompeii oven in Gloucester, Virginia.
    ok, so today I redid my IT and made it adjustable. Nothing fancy, just a piece of wood that glides, fastened by a butterfly nut.
    I also completed the first layer of tapered bricks. What a joy to cut bricks.
    I also made the entrance wall.
    For my next step, I am not exactly sure if I should do the arch first or run another layer of bricks on the dome.
    So far I am happy with the progress.
    I am not looking for a master piece, but something functional that will bake nicely and not collapse for a few years.
    https://www.flickr.com/photos/yannic...7644224444113/
    • Yannick
      • Mar 2014
      • 72
      #32
      Here is a little update of my oven.
      Today I started on the 5th layer. The angle is about 45 degrees.
      I am figuring out the dome to arch as I go.
      • NCMan
        • Jan 2014
        • 846
        #33
        Making nice progress there, Yannick. Can you smell the pizza yet?
        My Build:
        • Yannick
          • Mar 2014
          • 72
          #34
          oh man, I can't wait to fire up this baby.
          • Yannick
            • Mar 2014
            • 72
            #35
            Here is a little update on my project.
            I'm getting close to closing the dome. It's exciting.
            I'm using scrap bricks to do the 11th course since they are narrower.
            Not sure if I will fit through the arch to clean up the inside of the dome...
            Flue wize, I will use clay ones.
            Any size recommendation? I can find 8x8 (outside), 8x12, and I think 12x12 or 13x13.
            • Yannick
              • Mar 2014
              • 72
              #36
              I bought an 8x12 clay flue. I needed it for measurement and planning purposes.
              Today I had to remove my IT. I wanted to place a gym ball in the oven to help with the last bricks but my ball has holes in it. So I went to plan B, using a car jack and basketball. I'm super excited.
              Once I place the last brick on the dome I will redo my arch form to take in consideration the wider opening of the front.
              • Yannick
                • Mar 2014
                • 72
                #37
                Here is my little update.
                I finally plugged the dome friday night! That was such a great sense of accomplishment.
                For the plug, I had to cut a brick in half and cement the 2 halves to each other to get the proper width.
                The Heat Stop held during the cutting. Good sign.
                Today I redid my arch form to accommodate the wider entry size.
                For the chimney funnel, I think I will go with with a 35 degree angle. (picture 5)
                I traced the outline on the arch, does that look about right?
                • hubert_s
                  • Apr 2014
                  • 135
                  #38
                  Congratulations on closing the dome! Looks great.
                  • Yannick
                    • Mar 2014
                    • 72
                    #39
                    Thanks Hubert. Yours looks better but I take the compliment.
                      • 5260
                      #40
                      Kudos on plugging the dome.
                      • Yannick
                        • Mar 2014
                        • 72
                        #41
                        Thanks UtahBeehiver
                        • NCMan
                          • Jan 2014
                          • 846
                          #42
                          Great job! Pretty soon you'll be crankin' out some pizzas!! Congrats.
                          My Build:
                          • Yannick
                            • Mar 2014
                            • 72
                            #43
                            Today I received 3 boxes of ceramic blanket from DS Industries. I paid $192 with shipping.
                            Got my pizza peel and brush/scraper yesterday with a couple of olive oil pourers.
                            Things are coming together.
                            Just need for the rain to stop so I can continue the front arch!
                            Pizza dough is in proofing in the refrigerator for this weekend (on the grill, not the brick oven yet)
                            • Yannick
                              • Mar 2014
                              • 72
                              #44
                              Here is a little update.
                              I finished the front arch and started the base for the ceramic flue.
                              I had 2 lamps in the oven for about 3 weeks now. I think most of the moisture is out of the dome by now. What do you think?
                                • 5260
                                #45
                                What temps were you seeing, maybe 150-160 F??. Next step try some charcoal a couple times, that will get you to abt 250 and it is an even temp, no wild swings like a wood fire would do, then small fires. Good luck.
