Re: 100 cm oven build, Sweden
You can still scratch the surface lightly between coats, if you want to. But, you will probably not be as fast as a pro, so you may have to resort to imbedding nails into a homemade tool. Also, if you do scratch on a dry or simi-dry surface remove any loose material before applying the next coat. If you skip the scratch coat, don't skip the acrylic fortifier.
You can also skip the sponge step if you want. But, the sponge step works very well at evening flat surfaces or contours. When I did my dome, I was trying to "marry" techniques from two or three different trades that I have a had a "little" experience in. Though, I assure you, I am a master of none of them .
just sayin' .
Originally posted by ugnsnisse
View Post
just sayin' .
