Re: 40" Indoor Pompeii in NNY
Hi Darin,
Yes that is a very big concern for sure! I have looked closely at many builds to see how the transition into the chimney was constructed. I will take extra care to make sure no smoke exiting the dome arch bypasses the flue in the transition area. The vent pipe goes out the side wall into a 21' tall chimney so total length of chimney pipe is around 26'. It should draft well once it's warmed up. If all works as planned there won't be any smoke out the front except for a brief moment on the initial fire start up. If it becomes an issue I could make a partial outer door to block the upper portion of the outer arch for that first minute or two while the flue warms up. All in all this is a big learning experience and hopefully I have thought of all the potential issues!
Tony
Hi Darin,
Tony
