Several days ago, I began dry stacking my block. All of a sudden I realized that my block had a good deal of variation in height. They should be 7 5/8" tall, but some of them are from 1/4" to 3/8" taller than they are supposed to be!
There is also surprising (to me anyway) variation in the other dimensions. Some of the block are not square top to bottom - and sort of lean out or lean in.
Needless to say, the stacked block look bad...with big gaps here and there. I always thought concrete block were more uniform in size.
Is this a common issue?
Should I try to fill the gaps with mortar before I pour the cores?
