Sakrete Maximizer
  • edsiajb
    • Mar 2014
    • 143
    Sakrete Maximizer
    I'm making preparations to pour my hearth. I'm trying to decide between regular Sakrete and Sakrete Maximizer.
    Since Maximizer utilizes an "air entrained" aggregate (expanded shale) and is lighter weight, it would seem that it would be less thermally conductive. Does anyone know this for sure? And has anyone used Maximizer for the hearth because of these properties?
  • stonecutter
    • Jun 2007
    • 2003
    Re: Sakrete Maximizer
    Probably not, since any heat transfer through the insulation is minimal. If your structural slab is getting hot, you've got problems. Use either one.
    Old World Stone & Garden
    John Ruskin
    • edsiajb
      • Mar 2014
      • 143
      Thanks! I should have mentioned that my insulating layer will be 4" thick 5:1 vermiculite/portland cement. So there will be little or no transfer of heat through this 4" layer to the hearth?
        Any aggregate containing air will be weaker which in turn will make the concrete slab weaker and you then have to factor this into your design. You can make it stronger by making it thicker, but then you're back to square one.
        • edsiajb
          • Mar 2014
          • 143
          Thanks. I would think the same thing, but this Maximizer product is actually the strongest Sakrete I can buy - at least from a PSI perspective. Maximizer is rated at 5500 PSI while the regular product is rated at 3500 PSI.
          • Tscarborough
            • Oct 2009
            • 3341
            Maximizer uses expanded shale aggregate, so it is both lightweight and stronger than normal 3/8" pea gravel concrete mix.
            Since it does uses that particular aggregate, it is subject to a flash set while mixing. The expanded shale aggregate is very dry (oven dried) and highly absorbent, so I recommend adding all of the recommended water to 3/4 of the bag, mixing, then adding the last dry component after it is thoroughly mixed.
            • edsiajb
              • Mar 2014
              • 143
              Wow...thank you for this vital information. It sounds like it could ruin my mixer!
              • stonecutter
                • Jun 2007
                • 2003
                No, it just means you have less time to work with it. Use cold water too...hot water from the hose will accelerate the set.
                John Ruskin
                • Tscarborough
                  • Oct 2009
                  • 3341
                  It is not normally an issue in power mixers, just when you are mixing by hand. Still do it the same way I said. You will see the effect if it happens, the surface of the mix glazes over and gets shiny. In a power mixer, it breaks itself up, but if you mix as I suggested, you will not see it.
                  All cementious mixes suffer from flash set to one extent or another. In power mixing, it is not a concern, but when hand mixing concrete or cement based mixes, it is very easy to add too much water when it flash sets, then you have soup once you mix it some more.
                  • Tscarborough
                    • Oct 2009
                    • 3341
                    Stonecutter is right about the hose. I normally fill a couple five gallon buckets and pour from them into the mixer, it is easier to gauge how much you are putting in and it stays cool.
                      "Maximizer uses expanded shale aggregate" That sounds like LECA (lightweight expanded clay aggregate) which is good stuff, but expensive. How is the Maximiser for price?
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        Almost 2x.
                          Almost 2x.
                          Is that 2x LECA, or 2x standard aggregate?
                          • Tscarborough
                            • Oct 2009
                            • 3341
                            Regular 4000 psi concrete mix, .6 CuFt 80# bag - $3.70 (this is real concrete mix, not big box fence post garbage).
                            5500 psi Maximizer, 1 CuFt 80# bag - $6.75
                            • edsiajb
                              • Mar 2014
                              • 143
                              For my area, the entire hearth will cost about $15 more using the Maximizer.
