Hi all.
First off - what a great site! An absolute goldmine of information about building an oven. But you all know that anyway.
Thanks to all who have put in the time and effort to spread invaluable information on how to build these fantastic ovens.
I'm about to embark on a Pompeii project. Originally I was going to go for an all cobb oven as I have loads of clay soil I was planning to dig up and it'd be better to use it than carry it off site. However, the dig has been delayed/cancelled and I've got lots of engineering brick lying around and have been seduced by the better performance of brick ovens. So here comes a Pompeii igloo!
As I was planning to use cobb, this started as a zero cost project, so I'm trying to keep costs to an absolute minimum. The aim is to build an oven that achieves these aims:
- Can cook 2 pizza's at a time
- Can get to cooking temp in approx 1hr.
- Can cook for a weekend Fri to Sun (with an mid weekend firing if necessary)
- Can fit in the space I have available.
- Can be built with someone with virtually zero experience in brickwork, but competent at DIY.
- Cost around ?250 or less (I have most materials, but will spend on mortar, insulation and firebrick for the floor)
I would be extremely grateful for any comments and advice in achieving this.
My plan....
Base:
I have a retaining wall in my garden at just below waist height so my plan is to dig back the bank above this wall and put the oven structure on the soil. I will be using a ceramic fibre board as insulation under the oven floor, but do not want to put this straight onto the soil. I'm thinking of laying a base consisting of straw and empty beer bottles covered in sand. This will protect the CF board from the soil and will add extra insulation too. Then place the CF board on top of that. Any better ideas?
Oven Floor:
I have engineering bricks, but to reduce risk of cracking and increase performance I am planning to splash out on firebrick for the floor.
Dome:
I plan to build the dome using engineering brick and refractory mortar. I'll build a uniform dome with the aid of a self built indispensable tool. I'm hoping to fit a 36" dome, but that is looking tight for my location. What is the smallest dome I can get to and still cook a couple of pizza's at the same time?
Any experiences out there?
Dome Insulation:
CF blanket covered with chicken wire.
Outer coating:
- Trying to avoid buying render as that may break my budget, so I'm considering coating with clay/cobb dug up from my garden, but rain will wash that off over time I'd have thought or can I prevent this somehow? I'm also considering covering with earth so it looks integrated into the bank I've dug into. I'll try to add a photo to show the location. Maybe I could even grow plants/grass on it or is that a crazy idea? If I need to render, then I suppose I'll just have to.
Opening:
Brick arch with a brick flue.
Chimney:
Considering a pure brick chimney in a square formation or maybe a reclaimed clay pipe to keep with the circular theme. I haven't really worked this one out yet, but I don't want a bought metal chimney. Any ideas?
Door:
I'll build a door (probably out of aluminium as I have some of that around) with CF blanket completely enclosed within. Hopeful to fit a probe thermometer too.
Thanks for reading any advice welcome!
