Need help here... How much perlite will I need for a 4 inch layer of insulation over my 42 inch oven dome. My math says around 2,2 cubic meters and that seems a bit too much?
42" inside diameter + 4.5" brick thickness = 46.5" diameter to inside of insulation = 23.25" radius to inside of insulation +4" insulation = 27.25" radius to outside of insulation...
(23.25)^3 * 3.14159 / 2 = 19,741 cu in oven volume
(27.25)^3 * 3.14159 / 2 = 31,784 cu in volume to outside of insulation
Difference is 12,043 cu in / 1728 (# cu in in cu ft) = 6.97 cu ft
I did the math this way:
You have to subtract the volume of the dome without insulation from the volume of the insulated dome.
I would suppose that 42 is the inner diameter, and the brick thickness is 4 inch. Thus:
The UNINSULATED dome diameter is 42+4+4 = 50, r for uninsulated is: ru = 50/2 =25" = 0.635 m
The insulated dome diameter is 50+4+4 = 58 (4" insulation is considered), r for insulated ri = 58/2 = 29" = 0.737 m
Subtracting the volumes (We divide by 2 because domes are hemispheres):
[3.14*4/3*(ri^3-ru^3)] / 2 = 0.3 cubic meters of perlite required.
Please recheck my math for any mistakes.
I forgot who said that.
I did not check the math, but don't forget David's theory of 15% reduction in volume for V or P crete. I came up short on my floor insulation. So I did not make that mistake with my dome .
Gulf,
You mean the insulation volume should be 15% the dome volume?
Thanks v12spirit
Looks like 2 x 200 ltr. bags of perlite will do the job.
