captain; cracks in vermiculit
  • captain
    • Nov 2006
    • 43
    Hope every one is good I just opened the oven up for the season and noticed some cracks in the top coat of vermiculite I fired it up and was getting some heat loss before I put my finising coats of stucco what can I use to fill crack or should I channel out cracks and fill with vermiculite .
    Thanks for any help
  • CanuckJim
    • Jan 2006
    • 1480
    Re: captain; cracks in vermiculit
    Captain,
    Personally, I'd cut them out and back in a V-shape and refill with your vermic mix. Try to get to the depth of the crack and go wider than you think you have to. Mix a bit on the wet side and really press it in with a trowel. Let dry thoroughly. Should work.
    Cheers,
    Jim
    • captain
      • Nov 2006
      • 43
      Thanks for that quick respone that is what I will do.
      • CanuckJim
        • Jan 2006
        • 1480
        Captain,
        Whoops. One more thing. Use an old paint brush dipped in water and wet up the Vs a bit before you apply the fresh mix. You'll get better stick that way.
        Jim
