I am finalizing my design and would appreciate feedback on some of the features. It has taken sooooo long to get to this point.....
I am definitely building a 36" hemispherical dome, with a round arch, located in a house enclosure filled with insulation, and 3" insulation blanket. I'll be using a wooden arch template to locate the dome bricks.
I believe I have located the dome arch appropriately to intersect with the inside curvature of the dome.
I am trying to minimize the depth of the vent landing, for ease of use.
Does anyone see anything that might be a design flaw, I am particularly interested in thoughts on the following.
1) My design includes a heat break in the floor and between the dome and arch. Although I am a little leery about the structural effects of this, I believe it is similar to many successfully constructed ovens. In particular, I modeled much of it on Utahbeehivers' arch. The main difference is construction of the vent transition to the flue using insulating brick. This straddles the dome's arch and the vent arch, and would be a source of heat transfer.
My main intent is to maintain temp for baking on the following day. I will make an insulated door for the decorative arch as well. So, I'm not sure how much sense the heat breaks make in this situation.
2) Thoughts on depth of the counter in front of the oven?
Thanks,
Zoltan
Thanks,
Zoltan
