WFO built into retaining wall
Re: WFO built into retaining wall
There are a lot of different additives you can use to make concrete waterproof. Xypex does other things too, like enhancing strength. I think it is a better plan to use a standard render for the outer shell, then after around 10 firings the water should be entirely purged and the dome can be waterproofed. If you make the outer shell waterproof when it is first applied you are locking on moisture and therefore risk cracking the outer shell from steam expansion.Kindled with zeal and fired with passion.Comment
Great advice! But, (if you do) add a vent to the apex of the dome through the final render
Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
Yes, that's the stuff. I live in phonetic land. Anyway, to your other point - what holds water out also holds water in. So I don't think it would be good for a shell either. It's easier to use gravity to keep water off the dome. Just need a simple waterproof layer at the end. But for a hearth, it's great.
My $.02 on the reason this isn't in the plans is because it's not needed if you build an oven according to the plans. It only becomes necessary when you deviate.Comment
, if this material was to used to waterproof the dome, where is it applied?
