Cracks ??? How bad
  • Bubb
    • May 2014
    • 92
    Cracks ??? How bad
    Now getting ready for party I pressure washed stone
    But not dome. I've used twice before this, but never this
    Long or hot? Started at 3 pm slowly over 2 hours up to
    600 between 5-9 pm was in the 650 range. So it was hot
    For 6 hours... Just saw these crack this morning? They look
    To me to be expansion cracks yea but this is normal
    Right!! Not to be worried by them life goes on.
    • 5261
    Re: Cracks ??? How bad
    Those are wisdom lines.
    • Bubb
      • May 2014
      • 92
      By wisdom you mean should of had more
      and bigger thermal breaks. Thanks I'll finish
      The roof.
      • boerwarrior
        • Apr 2013
        • 454
        yes don't be worried - those cracks look smaller than normal!
        • GianniFocaccia
          • Jun 2009
          • 1645
          By wisdom you mean should of had more and bigger thermal breaks
          Nah! I got plenty thermal breaks and still got a tiny expansion crack here and there.
          Don't let 'em tell ya otherwise Every builder on this site has a crack
            • 5261
            I believe every oven has some cracks somewhere, if someone says their oven has no cracks then they are either a Politician or a used car salesman, LOL.
              Opinions are like cracks.............I mean cracks are like opinions.........Everybody................I mean............. every oven.............. has got one
              • Les
                • Sep 2005
                • 2945
                Not true - I have yet to see one. No clue what is going on under the Dryvit
                  Out side no...................inside?...................just, don't peak under the "covers" .
                  • Les
                    • Sep 2005
                    • 2945
                    I hear ya Gulf. That's the beauty of not using mortar where you can see it. On the back side of the brick - I have no clue. I am surprised that I see nothing in the entry - I did interlace the bricks pretty good so apparently the unit is one. Just waiting for the earthquake that is due, then we will see
