Returning to the project after a long break I noticed that the vermicrete layer was wet - ie saturated. Making a small hole through the stand above the bottom level of the vermicrete layer flowed with water. Therefore I conclude it has taken on water from above or below. My question is how do I deal with this?
I see some have also faced a similar issue and suggested drilling some drainage holes via the base.
Anybody got experience or good ideas.
I recognise firing the oven will dry out the layer slowly - not sure where the water will escape via - but this will surely be inefficient.
