I'm planning on a 42" pompei (low dome).
I cut my first bricks today just to make sure the saw actually works since it's borrowed. I have all the bricks (I hope), 2" ceramic fiberboard, 3" of insulating blanket, and dry mortar (brickseal bond is on the metal pails-I think it's from the UK). I'm leaning toward the stainless double wall pipe for the chimney and stucco on the oven to finish it.
Before I actually start assembly I have some questions:
1) should I put plastic under the insulating boards? If so, do they cover the entire hearth or just under the boards?
2) I see some talk about using a wet mix of sand, fireclay, and water to level the bricks on the fiberboard and they say the board soaks up the moisture rapidly. Does the board getting wet affect the structural ability of the board? Does it still insulate if wet?
Thanks in advance
Thanks in advance
