Okay I looked through numerous threads on this and keep bouncing back and forth on what is meant.
I let the oven dry for probably two weeks then started the curing process. What I am not sure about is the definition of "temperature"
It this the temperature of the core of the fire, the top, the inside bricks, the outside of the bricks. With a core temperature of 600 degree, the top of the fire could be 300, inside walls 100, and outside 50. So which one are we talking about?
I have not insulated yet so I can repair anything that might not be correct. Chimney is not capturing all the smoke (70/30), so may need to do some grinding there.
BUT, in heating the oven up each cycle, what temperature are you measuring. I have come to the conclusion it is the inside of brick temperature, as I can not possibly keep a fire below 300 degrees for more than 15 minutes let along for four hours.
Given this, I have warmed the internal bricks to 300, 350, and 400 now (obviously the fire is hotter) for 1-2 hours a cycle. Anyway, today a fine (1/32") crack appeared vertically along a grout path, but again I have read this is normal, yes?
But before i continue I wanted to make sure what I am doing is good for the oven and not killing it.
I can only heat it for 2-3 hours, not the four needed. Tomorrow I was going to heat the oven to 450, but again wanted to get some feedback as that would require some hot fire temperatures.
Also do people really get their oven up to 800+ before insulating it. Seem like you would need a LOT of wood and time to accomplish this.
